Набор 5 замков на рундуки под 1 ключ
У темі 2 долучень
Есть 5 рундуков.
Есть желание закрыть их на ключ (постановка на причале). Желательно на 1 ключ. Подскажите варианты замков и где их купить. (я пока нашел вариант на фото2) Заранее спасибо. |
Re: Набор 5 замков на рундуки под 1 ключ
у аблой есть мастер-ключ и замки похожие, но там цена вопроса....
Купил. Можно закрывать тему.
У темі 1 долучень
На ебее. "6pcs. IFAM 30mm KEYED ALIKE MARINE PADLOCKS. SALT SPRAY TESTED. ONE KEY FITS ALL"
OUR MARINE PADLOCK RANGE IS DESIGNED SPECIFICALLY FOR SEA-GOING AND COASTAL APPLICATIONS. RESISTANT TO SALT SPRAY AND CORROSION THIS RANGE IS WIDELY USED ON WORK BOATS, PLEASURE CRAFT, MARINAS AND LEISURE VEHICLES IN COASTAL LOCATIONS. ALSO USED IN MANY OTHER OUTDOOR AND INDUSTRIAL SITUATIONS WHERE CORROSION RESISTANCE IS IMPORTANT. THIS LISTING IS FOR 6 KEYED ALIKE PADLOCKS ALL WITH THE SAME KEY PATTERN. Marine quality 30mm Padlock. Keyed alike. Keyed Alike locks are normally ordered in sets of 2 or more to be used with the same key. For applications where it is convenient to operate multiple locks with the same key. We supply Keyed Alike locks in any quantity small or large. Each lock operates from the same key pattern. Each lock supplied with 2 keys. This model has passed all rustproof tests including more than 3000 hours salt spray tests to ASTM B-117, DIN-50021 & ISO-3768 Chrome plated extruded Brass Body Stainless steel shackle Stainless Steel components Double Locking mechanism Individually boxed. UK delivery and VAT included We ship worldwide. Buyers outside the UK please check Postage & Delivery tab for rates to your country. Please contact us if you need more information or if you need help with an unusual application. KEY DIMENSIONS . A = BODY WIDTH 30mm B = BODY HEIGHT 27mm C = SHACKLE INTERNAL HEIGHT 17mm D = SHACKLE DIA. 5mm L = SHACKLE INTERNAL WIDTH 15.5mm |
| Часовий пояс GMT +3. Поточний час: 13:35. |
