Старий 03.01.2011, 12:59   #21 (permalink)
Типово Re: Обсуждение Yamaha
Вот сравнивайте:
Model Number: DF140TL
Series: Four Stroke
HP: 140
Model Name: DF140
Horsepower: 140
Shaft Length (Inches): (20)
Weight (Lbs): (410)
Cylinders: In-line 4
Valves Per Cylinder: DOHC 4 Valves Per Cyl.
Valve Train Drive: Self adjusting oil bathed timing chain
Displacement: 124.7 cu. in. (2044 cc)
Bore and Stroke (Inches/mm): 3.38 x 3.46 in. (86 x 88 mm)
Operating Range (RPM): 5600-6200
Induction System: Sequential EFI
Starting System: Electric w/ Suzuki EFI
Lubrication: Wet sump
Oil Tank Capacity: 5.8 qt. (5.5 lit.)
Ignition: Solid State Electronic
Alternator: 12V 40A
Trim Type: Power Trim and Tilt
Gear Ratio: 2.59
CARB Emissions Rating: 3-Star Ultra Low
ype: Outboard Motor
Year: Current
Model: F150 HP
Model Number: F150TLR
Series: Four Stroke In-Line
HP: 150
Engine Type: 4 Cylinder
Displacement: 163 ci (2670 cc)
Borex Stroke: 94 x 96.2 mm (3.70 X 3.79in)
Prop Shaft Horsepower: 150 @ 5500 RPM
Compression Ratio: 9.0
RPM Range: 5000-6000
Fuel Induction System: EFI (DOHC)
Fuel Type: Unleaded gasoline (minimum pump octane 87)
Exhaust: Thru prop
Ignition System: TCI Micro Computer
CARB Rating: 3-Star
Alternator Outputat WOT: 35A
Lubrication: Wet Sump
Oil Capacity: 5.5 quarts
Recommended Engine Oil: Yamalube 4M
Gear Ratio: 2
Control Type: Remote
Trolling Throttle Adjustment: +/- 50 RPM increments (600 - 1000 RPM range) via Command Link System
Cooling: Water, Thermostatic Control
Weight: 466 lb. (212 kg)
Gear Shift: F-N-R
Command Link System: Optional Equipment
Enhanced Ultimate Corrosion Protection System UCP: Standard Feature
Power Trim and Tilt: Yes
Shaft Length: 20 inch
Получается на 6000 об. двигателя,винт у Сузы делает на 700 обор. меньше,а это ого го какая потеря в скорости.
Востаннє редагував в1961: 03.01.2011 о 13:05.
Старий 03.01.2011, 14:39   #22 (permalink)
О! Эт уже интересно.
Обращаем внимание на то что моторы для сравнения "немного" разные, точнее диаметр и ход поршня разный - 86 x 88 mm против 94 x 96.2 mm , соответственно и объем - 2044 cc против 2670 cc .
Суза, более оборотистая - 5600-6200 против 5000-6000 максимального крутящего момента ямы (точнее 5500яма и приблизительно6000суза), наверное здесь и нужена передача 2.59 против 2 менее оборотистой ямы.
Старий 03.01.2011, 15:06   #23 (permalink)
Да и смотрим разницу в весе. И вообще моторы совсем разные - Суза из серии 90-140, а Яма из серии 135-175.
Старий 03.01.2011, 18:40   #24 (permalink)
Так я про это и пишу,что Суза не тянет скоростной редуктор 1:2 против 1:2,59.Значит с заявлеными 140 л/сил не всё в порядке.
ПОВТОРЯЮ,если поставить редуктор от Ямы-150,то при включении передачи Суза, просто заглохнет
Старий 03.01.2011, 19:03   #25 (permalink)
Осмелюсь спросить. А мощность ПЛМ вычисляется с ступицы пропеллера или коленвала? Предполагаю что со ступицы , а сам ДВС конечно будет иметь другую мощность.
Т.е. если теоретически раскрутить ДВС до 10000т.об., то и редуктор надо будет 1 к 4, если понизить макс.крут.момент до 2500, то редуктор будет 1 к 1 , это если мощность ДВС будет одинаковая.
Некорректно сравнивать несравнимое.
Старий 04.01.2011, 01:43   #26 (permalink)
Псевдо: was
Звідки Ви: Почти Киев
Карапь: галоша
Дописи: 902
Сказал(а) спасибо: 51
===== Конечно суза заглохнет, если редуктор Ямахи-150 ,,убитый,, , без масла заржавевший и непроворачивается.
Востаннє редагував Вовчик: 04.01.2011 о 02:12. Причина: Подправил цитату
Старий 04.01.2011, 02:48   #27 (permalink)
Аватар для RINO
Звідки Ви: Київ, Україна
Дописи: 15.275
Сказал(а) спасибо: 10.342
Пацаны! Я не разбираюсь во всех этих ваших оборотах и передаточных числах (не хочу/не интересно), но просто из практики:
-пробовал Бастер ХL под 140-ой сузой - ...ну, шо-то там тянет, но как мертвая рыба...
-моя родная Хонда-150 - уверенно и приятно...
-пробовал Бастер ХХL два раза (старый и новый) под Ямой-150 - ощущение, как на самолёте...
Это - ВСЁ...
СМЕРТЬ РАШИСТАМ!!!
Старий 06.01.2011, 00:09   #28 (permalink)
Аватар для Бодя
Псевдо: Богдан
Звідки Ви: Riviera Riverside
Дописи: 8.332
Сказал(а) спасибо: 5.460
Это - ВСЁ...
Ну всё правильно, 140-ка будет конечно не так тянуть как 150-ти сильные моторы, ты бы Сузуку 150 повесил и тогда можно сравнивать.
Старий 10.01.2011, 18:19   #29 (permalink)
Аватар для bethov
Звідки Ви: Красноярск
Карапь: прогресс 2м
Дописи: 413
Сказал(а) спасибо: 131
Опять улыбнуло.
Может сравним тех.характеристики?
А то получается то ли прямой угол, то ли точка кипения .
Лучшие 2х тактные моторы-YAMAHA.TOHATSU.2х тактный двигатель-это живой двигатель.он дышит,поет,если конечно это слышит человек(в частности).suzuki вообще выпускает лодочные моторы недавно.Поэтому сравнивать новичка и корифея немного не корректно.ему еще расти и расти до ямахи.
Востаннє редагував bethov: 11.01.2011 о 18:55.
Старий 05.05.2011, 08:53   #30 (permalink)
Вопрос к владельцам Ямах 4-х тактн.
На щупе проверки уровня масла имеется только насечка, надписей мин. макс. нет!
Где должен быть оптимальный уровень? У нас сейчас в самой верхней точке насечки! Это правильно, или перебор? Отходили прошлый сезон, ничего не доливали, но возникли сомнения .
Благодарю!
Старий 05.05.2011, 09:42   #31 (permalink)
По идее насечек есть две:одна внизу,вторая на пару см. выше,а между ними и есть "уровень".
Соответственно мин. и мах.,а между ними "золотая середина".Я всегда не доливаю до МАХ.
Во наваял
Fix (05.05.2011)
Старий 05.05.2011, 10:14   #32 (permalink)
Вся длина насечки и есть допустимый уровень масла. Чтоб не прогадать держи его посередине несечки.
Fix (05.05.2011)
Старий 05.05.2011, 18:55   #33 (permalink)
Витя, Ларик, благодарю!
Так, примерно и думал! Держу уровень ,чуть выше середины насечки!
Старий 05.05.2011, 21:55   #34 (permalink)
Аватар для Anatol
Дописи: 788
Сказал(а) спасибо: 35
Держу уровень для подстраховки в районе МАХ, потому как не авто двигатель. При переходе меляк и отходе с мелкоты, тримом подымается мотор и горизонт уровня смещается, трошки бздю, что бы не было "маслянного голодания". Хотя и уверен, что "япошка" предусмотрел такие варианты. Но боюсь что умный иженерюга со страны восодящего солнца прдесмотрел что НАШИ "отдохнувшие" водкомоторники могут запустить двигатель при полностью поднятой ноге.
Старий 06.05.2011, 10:31   #35 (permalink)
Аватар для Бодя
Псевдо: Богдан
Дописи: 8.332
Глянул я в начало темы и увидел некую не справедливость,сравнивать то надо равные моторы по мощности. Вот ттх по Сузе 150, по цифрам видно, что Яма курит
Model Name: DF150
Horsepower: 150
Shaft Length (Inches): L (20), X (25)
Weight (Lbs): L (474), X (485)
Cylinders: In-line4
Valve Train Drive: Self adjusting oil bathed chain
Displacement: 174.9 cu. in. (2867 cc)
Bore and Stroke (Inches/mm): 3.81 x 3.81 in. (97 x 97 mm)
Operating Range (RPM): 5000-6000
Alternator: 12V 44A
Gear Ratio: 2.50:1
CARB Emissions Rating: 3-Star Ultra-Low
Range of Avail. Optional Propeller Pitches: 17 - 27
Старий 06.05.2011, 16:19   #36 (permalink)
Вчера видел как Сузу-140 вешали на ХЛ....
Заметил прикол, на бирке мотора написан вес 182 тире 204 кг.
Получается, что дурят они с весом потребителя,указывая в прайсах нижний порог.
Богдан, а на твоей что написано на бирке?
Старий 06.05.2011, 16:23   #37 (permalink)
Дописи: 9.887
................Даже если предположить, что нижний предел веса указан без технических жидкостей, все равно как то не сплясывается . Вот паразиты, дурят нашего брата водно-моторника , или мы чего то не учитываем.
Старий 06.05.2011, 16:34   #38 (permalink)
Аватар для Бодя
Псевдо: Богдан
Дописи: 8.332
На моей 155-172 (может чуть ошибаюсь), но есть такое,думаю что связано с длинной ноги, есть ведь длинная и экстра длинная
А вообще как буду у Лёши поинтересуюсь
Старий 06.05.2011, 16:48   #39 (permalink)
уже не с нами
Карапь: Амур Merc115
Дописи: 859
Сказал(а) спасибо: 239
Ни на что не претендую, но в каком-то обзоре-тесте-драйве читал, что Сузуки наиболее честно дают вес. Другие могут давать не только без жидкостей, а и без винта.
Старий 06.05.2011, 19:20   #40 (permalink)
Аватар для Бодя
Псевдо: Богдан
Дописи: 8.332
Допис від esvesk Переглянути допис
Например когда 2 года назад выбирал 15-ки 2т.,то Мерки давали вес без гребного винта,самый точный вес был у Ямы и Сузы
Продам YAMAHA 30 HMHS promokan Архив 2 30.01.2011 20:15
Продам двигатели Yamaha-40,50,60л.с Bfg9000 Архив 6 19.01.2011 00:17
Моё ДУ на Yamaha-5 sidorovva Подвесные импортные брендовые 1 24.11.2010 21:40
Сервисный центр Yamaha! Bfg9000 Архив 2 26.10.2010 01:03
YAMAHA 40HEMO yura1102 Подвесные импортные брендовые 5 22.06.2010 11:49
Часовий пояс GMT +3. Поточний час: 21:40.
