Старий 03.03.2018, 21:51   #1 (permalink)
Типово Зарядное для любых АКБ
Зарядное морского исполнения для любых АКБ 20А и 30А.
На 2 и на 3 АКБ. Имеет принудительное охлаждение. Автономный режим.
Цена 20А на 2 и на 3 АКБ - 300дол.
Цена 30А на 3 АКБ - 350дол.
Есть другие варианты.
Тел. 0977421083 Виктор.
Turbo M330V2 - Triple Bank Waterproof Onboard Charger - 12/24/36V DC - 30 Amp
The Turbo M330V2 is based on the same compact and waterproof design of the
first-gen Turbo M330. The V2 inherits all the features from the original
Turbo M, including its ability to charge 0-volt dead batteries, to maintain
100% output at 90V AC, and to intelligently allocate more power to weaker
batteries for speedy recharge. The M330V2 is now 25% lighter, runs cooler
(up to 25°F), and provides charge status and error check for each
individual output.
3 Stage Smart Charge
Turbo M charges battery in three sequential stage - Bulk, Absorption, and Float. This mechanism is proven to bring battery to its fullest charge, and also to maintain battery from self discharge.
Adaptive Loading
A multi-output Turbo M charger can actively adjust each of its individual output loading and completes charging cycles in the shortest time possible.
Waterproof
Turbo ME is fully epoxy potted for true, long-term waterproof, shock and corrosion-resistant. It is IP65 rated (Ingress Protection) for splash proof.
Selectable Charging Profiles
Turbo MV2 allows the user to select different types of 12V DC batteries to charge. The initial factory setting is at "Flooded Lead Acid / AGM Charge Mode". The other two charge modes are "Gel Charge Mode" and "AGM+ Mode". AGM+ is for charging high-performance AGM type battery (Odyssey and Optima brands AGM)
Active Cooling
The Turbo M330V2 is equipped with a waterproof cooling fan. This temperature-controlled fan switches on and off automatically to help dissipate excess heat build up.
Charge 0-Volt Battery
Turbo MV2 can be used to revive a 0-volt battery that has accumulated too much build up or has been allowed to sit unused for several months. It could take several days of charging to bring battery voltage to a normal level. Unless the battery has one or more shorted cell, Turbo M can save battery while most others cannot.
Full Output at 90V AC
Turbo MV2 delivers full output even if input AC voltage been dropped to 90V. In less than ideal charging setup using alternative power sources such as generator power or shore power via long extension cords, Turbo MV2 performs just as well as it was provided with full 120V AC from a standard power outlet.
Global AC (120/240V AC) Input
Turbo MV2 accepts global AC input (120/240V AC). It automatically senses the input voltage and adjusts accordingly.
Individual Charge Status
The Turbo MV2 features individual charge status / connection check light for each DC output: red for charging, green for ready, and amber for a faulty battery or connection.
Individual Connection Check
2 Year Warranty
Powermania, at its disretion, provides 2 year limited warranty on Turbo M Chargers against defects in materials or workmanship under normal use.
Specifications:
Norminal Input Voltage: 120 /240V AC
Norminal Input Frequency: 50 - 60Hz
Maximum Input Current (@120V AC): 4.7 Amps
Total Output Current: 30 Amps
Output Voltage / Bank: 13.4 - 14.7V DC
Number of Output Bank: 3 (Prewired)
Output Voltage Configuration: 12/24/36V DC
Battery Type Setting: 1.Flooded (Lead-Acid) / AGM 2.GEL 3.AGM+
Charging Voltage (Flooded / AGM): 14.6V (Absorption) / 13.5V (Float)
Charging Voltage (GEL): 14.1V (Absorption) / 13.8V (Float)
Charging Voltage (AGM+): 14.7V (Absorption) / 13.6V (Float)
Operational Temperature: -4°F - 122°F
Storage Temperature: -40°F - -185°F
Output Cable Length: 6'
AC Power Cord Length: 6'
Dimension: 10.75" x 7.0" x 3.25"
Weight: 13.5lb
DC Wire Gauge: 12 AWG
LED Indicatior:
Power
Monitor Mode
Over-Voltage Indicator
Overheat Indicator
AGM+ Charge Mode
Gel(Gel Cell) Charge Mode
Lead-Acid / AGM Charge Mode
Safety Features:
Ignition Protection
Overheat Protection
Over-Current Protection
Over-Voltage Protection Protection
Reverse Polarity Protection
Short-Circuit Protection
Compliance
FCC Class A
CE
IP65 (Splash Proof)
Marine UL 1236
CSA C22.2 N0. 107.2
California Energy Commission (CEC)
Additional Specs (If Applicable):
Amps - Output = 30 Amps
Amps Per Bank = 10 Amps
Banks = 3
Battery Type = N/A
Charger Type = N/A
Portable = N/A
Voltage - Charger Input = 120/240V
Voltage - Output (Volts) = 12/24/36V
Назва:  пр.jpg
Переглядів: 454
Розмір:  351,2 КБ
Востаннє редагував в1961: 03.03.2018 о 21:56.
Старий 14.03.2018, 09:39   #2 (permalink)
Типово Re: Зарядное для любых АКБ
ЗАРЯДНОЕ ДЛЯ ТРОЛИНГОВЫХ МОТОРОВ
ZARADNOE DLJA TROLINGOVIX MOTOROV
Востаннє редагував в1961: 15.03.2018 о 10:25.
Старий 14.03.2018, 13:46   #3 (permalink)
Аватар для Antonioni2007
Звідки Ви: Киев Роп 6
Дописи: 3.118
Сказал(а) спасибо: 1.019
"Кучерявые" зарядные.
vlad2002 (14.03.2018), Юрій_ (14.03.2018)
Старий 14.03.2018, 17:20   #4 (permalink)
Я бы еще добавил - "нафиг не нужные".
У меня было две лодки с двумя аккумуляторами каждая.
На любую из двух бы не купил. Смысла нет.
А вот в кемпер - да. Отличная тема если ездить не по европе.
Там только вопрос цены возникнет, потому как те решения дешевле.
Не видел правда на три аккумулятора, но то такое...
Старий 14.03.2018, 21:46   #5 (permalink)
Аватар для Петров Саша
Карапь: длинномер + надувас
Дописи: 1.417
Сказал(а) спасибо: 347
в кемпер на крышу солнечных панелей наложил и накой те зарядки?
аппарат для частых пользований аккумов электро моторами, за ночь зарядил три аккума и утром в бой .
в1961 (14.03.2018)
Параметри теми
Параметри перегляду
Зарядное устройство Dual Pro PS2 Two 15Amp Predator Бытовая барахолка 2 04.07.2018 00:33
зарядное устройство ProMariner Voha1 Электрика 6 30.11.2017 08:33
Продам зарядное-блок питания 12В. vasylij Бытовая барахолка 16 02.07.2017 20:44
Зарядное устройство для 12в АКБ logvinenko Архив 3 13.03.2017 11:24
Зарядное устройство. санек 75 Архив 5 28.12.2014 22:03
Часовий пояс GMT +3. Поточний час: 18:02.
