Старий 03.01.2011, 11:18   #1 (permalink)
Типово Re: Обсуждение Yamaha
Опять улыбнуло.
Может сравним тех.характеристики?
А то получается то ли прямой угол, то ли точка кипения .
Старий 03.01.2011, 11:59   #2 (permalink)
Вот сравнивайте:
Model Number: DF140TL
Series: Four Stroke
HP: 140
Model Name: DF140
Horsepower: 140
Shaft Length (Inches): (20)
Weight (Lbs): (410)
Cylinders: In-line 4
Valves Per Cylinder: DOHC 4 Valves Per Cyl.
Valve Train Drive: Self adjusting oil bathed timing chain
Displacement: 124.7 cu. in. (2044 cc)
Bore and Stroke (Inches/mm): 3.38 x 3.46 in. (86 x 88 mm)
Operating Range (RPM): 5600-6200
Induction System: Sequential EFI
Starting System: Electric w/ Suzuki EFI
Lubrication: Wet sump
Oil Tank Capacity: 5.8 qt. (5.5 lit.)
Ignition: Solid State Electronic
Alternator: 12V 40A
Trim Type: Power Trim and Tilt
Gear Ratio: 2.59
CARB Emissions Rating: 3-Star Ultra Low
ype: Outboard Motor
Year: Current
Model: F150 HP
Model Number: F150TLR
Series: Four Stroke In-Line
HP: 150
Engine Type: 4 Cylinder
Displacement: 163 ci (2670 cc)
Borex Stroke: 94 x 96.2 mm (3.70 X 3.79in)
Prop Shaft Horsepower: 150 @ 5500 RPM
Compression Ratio: 9.0
RPM Range: 5000-6000
Fuel Induction System: EFI (DOHC)
Fuel Type: Unleaded gasoline (minimum pump octane 87)
Exhaust: Thru prop
Ignition System: TCI Micro Computer
CARB Rating: 3-Star
Alternator Outputat WOT: 35A
Lubrication: Wet Sump
Oil Capacity: 5.5 quarts
Recommended Engine Oil: Yamalube 4M
Gear Ratio: 2
Control Type: Remote
Trolling Throttle Adjustment: +/- 50 RPM increments (600 - 1000 RPM range) via Command Link System
Cooling: Water, Thermostatic Control
Weight: 466 lb. (212 kg)
Gear Shift: F-N-R
Command Link System: Optional Equipment
Enhanced Ultimate Corrosion Protection System UCP: Standard Feature
Power Trim and Tilt: Yes
Shaft Length: 20 inch
Получается на 6000 об. двигателя,винт у Сузы делает на 700 обор. меньше,а это ого го какая потеря в скорости.
Востаннє редагував в1961: 03.01.2011 о 12:05.
Старий 03.01.2011, 13:39   #3 (permalink)
О! Эт уже интересно.
Обращаем внимание на то что моторы для сравнения "немного" разные, точнее диаметр и ход поршня разный - 86 x 88 mm против 94 x 96.2 mm , соответственно и объем - 2044 cc против 2670 cc .
Суза, более оборотистая - 5600-6200 против 5000-6000 максимального крутящего момента ямы (точнее 5500яма и приблизительно6000суза), наверное здесь и нужена передача 2.59 против 2 менее оборотистой ямы.
Старий 03.01.2011, 14:06   #4 (permalink)
Да и смотрим разницу в весе. И вообще моторы совсем разные - Суза из серии 90-140, а Яма из серии 135-175.
Старий 03.01.2011, 17:40   #5 (permalink)
Так я про это и пишу,что Суза не тянет скоростной редуктор 1:2 против 1:2,59.Значит с заявлеными 140 л/сил не всё в порядке.
ПОВТОРЯЮ,если поставить редуктор от Ямы-150,то при включении передачи Суза, просто заглохнет
Старий 03.01.2011, 18:03   #6 (permalink)
Осмелюсь спросить. А мощность ПЛМ вычисляется с ступицы пропеллера или коленвала? Предполагаю что со ступицы , а сам ДВС конечно будет иметь другую мощность.
Т.е. если теоретически раскрутить ДВС до 10000т.об., то и редуктор надо будет 1 к 4, если понизить макс.крут.момент до 2500, то редуктор будет 1 к 1 , это если мощность ДВС будет одинаковая.
Некорректно сравнивать несравнимое.
Старий 04.01.2011, 00:43   #7 (permalink)
Псевдо: was
Звідки Ви: Почти Киев
Карапь: галоша
Дописи: 902
Сказал(а) спасибо: 51
===== Конечно суза заглохнет, если редуктор Ямахи-150 ,,убитый,, , без масла заржавевший и непроворачивается.
Востаннє редагував Вовчик: 04.01.2011 о 01:12. Причина: Подправил цитату
Старий 04.01.2011, 01:48   #8 (permalink)
Аватар для RINO
Звідки Ви: Київ, Україна
Дописи: 15.275
Сказал(а) спасибо: 10.342
Пацаны! Я не разбираюсь во всех этих ваших оборотах и передаточных числах (не хочу/не интересно), но просто из практики:
-пробовал Бастер ХL под 140-ой сузой - ...ну, шо-то там тянет, но как мертвая рыба...
-моя родная Хонда-150 - уверенно и приятно...
-пробовал Бастер ХХL два раза (старый и новый) под Ямой-150 - ощущение, как на самолёте...
Это - ВСЁ...
СМЕРТЬ РАШИСТАМ!!!
Старий 10.01.2011, 17:19   #9 (permalink)
Аватар для bethov
Звідки Ви: Красноярск
Карапь: прогресс 2м
Дописи: 413
Сказал(а) спасибо: 131
Опять улыбнуло.
Лучшие 2х тактные моторы-YAMAHA.TOHATSU.2х тактный двигатель-это живой двигатель.он дышит,поет,если конечно это слышит человек(в частности).suzuki вообще выпускает лодочные моторы недавно.Поэтому сравнивать новичка и корифея немного не корректно.ему еще расти и расти до ямахи.
Востаннє редагував bethov: 11.01.2011 о 17:55.
Продам YAMAHA 30 HMHS promokan Архив 2 30.01.2011 19:15
Продам двигатели Yamaha-40,50,60л.с Bfg9000 Архив 6 18.01.2011 23:17
Моё ДУ на Yamaha-5 sidorovva Подвесные импортные брендовые 1 24.11.2010 20:40
Сервисный центр Yamaha! Bfg9000 Архив 2 26.10.2010 00:03
YAMAHA 40HEMO yura1102 Подвесные импортные брендовые 5 22.06.2010 10:49
Часовий пояс GMT +3. Поточний час: 01:28.
