Псевдо: Владислав
Звідки Ви: Самара
Карапь: Finval 505
Дописи: 58
Сказал(а) спасибо: 15
Поблагодарили 18 раз(а) в 10 сообщениях
У нашего товарища подобный случай произошёл прошлым летом в 30 градусную жару. Дилер отказал в гарантийном ремонте. 75/80/90/100/115 FourStroke 2.1L 2B385583 and Below. Моторы с номером меньше этого подлежат доработке. Ниже выписка из бюллетеня по доработке: Subject: Exhaust Pipe Update, Raised Exhaust Relief Opening – 75/80/90/115 FourStroke (2.1L) Models Affected Models Serial Number 75/80/90/100/115 FourStroke 2.1L 2B385583 and Below Situation In an effort to reduce the occurrence of hydro-locked power heads following a panic stop maneuver, Mercury Marine has relocated (raised) the exhaust relief opening in the exhaust pipe. This modification will provide an additional margin of tolerance to customers who unintentionally perform this maneuver. These hydro-lock damaged power heads are not covered under warranty. Customers who are replacing a power head due to a hydro-lock should be encouraged to also upgrade to the new exhaust pipe. Exhaust Pipe Replacement – 75/80/90/100/115 FourStroke (2.1L) IMPORTANT: Refer to Outboard Service Manual 90-8M0109954 for in depth service procedures. Disassembly 1. Drain the engine sump. 2. Remove top and lower cowls. Refer to Section 5A Lower Cowl - Removal. 3. Remove the gear housing. Refer to Section 6A/B/C, Gear Housing Removal. 4. Remove the fuel supply module. Refer to Section 3C, FSM Removal. 5. Remove the speedometer tube from the fitting on the driveshaft housing. 6. Remove the fuel supply module water supply hose and block drain hoses from the water strainer. Refer to Section 5B, Driveshaft Housing/Adaptor Plate Disassembly. 7. Remove the lower mount bolt and locknut from both the Port and Starboard lower mounts. Refer to Section 5A, Lower Mounts. 8. Remove the driveshaft housing from the adapter plate. Refer to Section 5B, Driveshaft Housing/Adaptor Plate Disassembly. 9. Remove the exhaust pipe from the adaptor plate. Refer to Section 5B, Adaptor Plate/Oil Pump. New Exhaust Pipe Note: The new exhaust pipe is identified by higher location of the exhaust relief hole. |
bmw325e90 (19.04.2019),
Don Pedro (19.04.2019),
exceptional (19.04.2019),
ohotanarybalku (20.04.2019)
| Параметри теми | |
| Параметри перегляду | |
| Отзывы Finval 570 | qwert123 | Finval | 38 | 27.09.2013 08:38 |
| Приглашаем на презентацию Finval 505 Fish Pro | Руслан 35 | Finval | 101 | 24.08.2013 14:09 |
| Продам 1997 Sunbird 170 Fish & Ski | Denis 840 | Архив | 15 | 19.03.2013 00:21 |
| Силовой набор Buster L, Finval 470 и Finval 500 | __Sava__ | Катера, лодки | 6 | 23.07.2012 12:41 |
| Finval 570 в Крыму | Игорь ims | Finval | 18 | 23.11.2011 17:29 |
